All Falcon Gauge airspeed indicators are housed in an aluminum case and all parts are made with metal. Т.е., все в алюминиевом корпусе и все части из металла.
1. Указатель скорости 200 км/ч:
Model: ASI200K-3
Range: 0-200 KPH
Length: 2.2in/56.5mm
Weight: 10.2oz/290g
2. Вариометр
FALCON GAUGE VERTICAL SPEED INDICATOR - 3-1/8 INCH 10 METER RANGE
Falcon Gauge Vertical Speed Indicators (Rate of Climb), have been installed in thousands of planes. Available in climb ranges from 2,000 feet per minute to 4,000 feet per minute and 10 meters per second.
3. Высотомер
FALCON GAUGE NON-SENSITIVE ALTIMETER WITH BAROMETRIC WINDOW - 10,000 FEET, MILBARS
Three pointer Altimeter features a barometric window enable the pilot to adjust the altimeter to the barometric conditions existing at the point of landing. This type is available in 20,000 ft, which can be ordered with window reading inches of mercury or millibars.
4. Магнитный компас
Falcon Gauge Magnetic Compasses are available in liquid type. The Liquid Type provides an accurate reading at a low cost. It is fluid damped and incorporates a thermal expansion chamber and compensation magnet. For Kit Planes, Gyro Copters and Ultra-Lights these magnetic compasses will help pilots navigate to their destination
И так далее. Цена здесь в Москве будет около (плюс-минус в зависимости от закупочной) 190 долларов каждый.
От объёма заказа - договорные условия - в личку.
