МиЛ
Буду летать на аэрошюте!
- Откуда
- Красноярск
НОВАЯ.
Цена 4900р
Доставка по РФ БЕСПЛАТНО (срок поставки 3-5 недель)
Совместима с / Kenwood / ICOM / Linton / PUXING / WEIERWEI / QUANSHENG / WOUXUN
Specifications:
Technical Specifications of Speakers:
Passive Noise Reduction Rating (NRR): 24dB;
Impedance: 8[ch937] +/- 15% at 1.0v, 800Hz;
Resonant Frequency: 200Hz +/- 20% (without baffle);
Output SPL: 99dB +/- 3dB (at 1W Zxis Calculated);
Frequency Response: 15kHz;
Rated Frequency Range: 15kHz;
Rated Power Input: 0.5W;
Max Power Input: 0.6W;
Distortion: 5% Max (rated power input 1000Hz);
Load test: Noise 0.5W in 24 hours;
Heat test: 50+/-2°C and 20-25% R.H. in 5 hours;
Humidity test: 40+/-2°C and 90-95% R.H. in 5 hours;
Cold test: -25 °C in 16 hours;
Technical Specifications of Microphone:
Sensitivity: -43dB (f=1kHz, 0dB=1V/Par VS=4.5V, R=1.0k[ch937]);
Output Impedance: 1.0 k[ch937] (f=1KHz);
Current Consumption: 500[ch956]A (VS=4.5V, RL=1.0K[ch937]);
Signal to Noise Ratio: 40dB;
Decreasing Voltage: -3dB (VS=3.0V to 1.5V);
Soldering heat shock: +/-3dB (350+/-5°C in 3 minutes);
Storage temperature range: -40<°C~+80°C;
Operation temperature range: -40<°C~+70°C;
High temperature test: 55+/-2°C in 2 hours;
Humidity test: 40+/-2°C and 93+2/-3% R.H. in 48 hours;
Low temperature test: -20+/-3°C; Vibration test: requency range=10~30~10Hz; amplitude=0.55mm; time for each period=3 min.; total time=30min; frequency range=30~55~30Hz; amplitude=0.15mm; time for each period=3 min.; total time=30min.
Applicable radios
Kenwood handheld Radio :
KPG27D, KPG29D,KPG48D, KPG49, KPG55D, KPG56D, KPG62D, KPG66D, KPG69D, KPG70D, KPG74D, KPG75D, KPG77D, KPG82D, KPG87D
TH-D7, TH-D7A, TH-D7AG, TH-D7E, TH-F6, TH-F6A, TH-F7, TH-F7E, TH-G71, TH-G71A, TH-G71E, TH-K2, TH-K2A, TH-K2E, TH-K2ET, TH-21, TH-21AT, TH-21BT, TH-22, TH-22A, TH-22AT, TH-22E, TH-25, TH-26, TH-27, TH-28, TH31AT, TH31BT, TH41AT, TH41BT, TH-42, TH-42A, TH-42AT, TH-42E, TH-45, TH-46, TH-47, TH-48, TH-55, TH-75, TH-77, TH-G71, TH-205, TH-215, TH-225, TH-235, TH-235A, TH-235E, TH-315, TH-415,
TK-208/308, TK-220/320, TK-240/340, TK-240D/340D, TK-248/348, TK-250/350/353, TK-260/360, TK-260G/360G, TK-270/370, TK-270G/370G, TK-272G/372G/373G, TK-278G/378G/388G Pro-Talk, TK-430/431, TK-2100/3100 Pro-Talk, TK-2102/3102 Pro-Power, TK-2107/3107 Pro-Talk, TK-2160/3160, TK-2170/3170/3173, TK-2200/3200, TK-3101/3131 Free-Talk, TK-3130.TK-2207/3207.
LINTON handheld Radio : LT-2288, LT-3288, LT-6288, LT-5288, LT-3188, LT-2188, LT-3260, LT-2268, LT-3268 , LT6188, LT3288
PUXING handheld Radio : PX-777, PX-777 PLUS, PX-888, PX-3288
WEIERWEI handheld Radio : VEV-3288S,VEV-6288,VEV-3288
QUANSHENG handheld Radio: TG-K4AT TG-2AT,TG-45AT,TG-42AT,TG-22AT,TG-25AT
WOUXUN handheld Radio: KG-659, KG-669 , KG-669 PLUS, KG-679, KG-679 Plus, KG-689, KG-689 PLUS
Feidaxin / FDC handheld Radio: FD-268A, FD-268B
Цена 4900р
Specifications:
Applicable radios
