Продается Cessna-T337H
Алматы
Продается самолет Cessna-T337H, наработка 1380ч, " два движка TSIO-360HB по 210 лошадок (тянитолкай турбовый)  1980г\в., ПОС., двухосевой автопилот, убирающиеся шасси, и т.д.
    11,8 КБ · Просмотры: 393
    31,5 КБ · Просмотры: 405
    16,4 КБ · Просмотры: 384
@Yura24...у тебя новая оценочная величина, в Илах? 😀 😉
@AirKZ...смотри пример!...как Цесснами торгуют......и вопросы сразу отсутствуют...
[highlight]Equipment Specifications [/highlight]
Year      1969
Manufacturer      CESSNA
Model      T337
Price      US $110,000
Location      Clio, California
Condition      USED
Total Time      1510 Hours
Number Of Seats      5
[highlight]General Information [/highlight]
Only 1510 Total Time, 434 / 265 SMOH, Garmin GNS-530/430 Garmin GTX-327 Txp, Garmin GMA-340 Audio, Slaved HSI, S-TEC A/P, Long Range Fuel, Strobes.
[highlight]Detailed Description [/highlight]
Low Time Aircraft - Very Clean - Excellent and Complete Logs - Excellent Radio Package - Excellent Maintenance History - All AD's Completed - October Annual - Hangared - Owner lost Medical and must sell.
[highlight]Airframe:[/highlight]
[highlight]Damage History: [/highlight]
Ground Looped Damaged in (5/71) - Belly Landing in (5/76) - Nose Gear Collapsed in (10/02)
Engine Specs:
Two Continental TSIO-360-A/B (210 HP Each - 1400 TBO)
FE: 434 SFRMAN TCM - Continental (VAR Crank) (5/97) S# 197112-R
RE: 265 SFRMAN. TCM - Continental (VAR Crank) (3/00) S# 197125-R
Prop(s):
Two McCauley (Two Blade Metal - Variable Pitch)
FP: 142 SPOH 2AF34C91-AMP S# 670792 Executive Propeller - Van Nuys, CA (10/02)
RP: 265 SPOH D2AFD34C-KO S# 804208 Byron Propeller Service (02/04)
Modifications/Conversions:
New C&D Glass Combustion Cabin Heater
1351 Lbs. Useful Load
Avionics/Radios:
Garmin GMA-340 Audio Panel w/ 3 LMB
Garmin GNS-530 Nav Com / GPS w/ Color Moving Map (IFR Approved)
Garmin GNS-430 Nav Com / GPS w/ Color Moving Map
Garmin GI-106A Nav Indicator #2 w/ Glide Slope
Garmin GTX-327 Transponder w/ Encoder
S-TEC SYS- 50 Autopilot w/ Altitude Hold
S-TEC ST-180 HSI (Slaved)
ELT
Additional Equipment:
DeIce Boots (Some Patches)
Hot Prop (Front)
Wing Ice Light
Factory Oxygen System
TIT (Turbine Inlet Temperature - Electronics International)Electric Cowl Flaps
Turn Coordinator
Wing Tip Strobes
Pilot & Co-Pilot Mike Buttons
Bendix Mags
Hamilton Vertical Compass
Avionics Master Switch
Wired for Shadin Mini Flow Fuel Computer
Davtron M877 Digital Chronometer
Rear Engine Access Door Mod
Metal to Metal Seat Belts
Exterior:
Original Matterhorn White w/ Red Trim and Black Stripes (4/10)
Interior:
Five Seats in Tan Fabric & Vinyl - White Vinyl Headliner and Brown Carpet (6/10)
Inspection Status:
Annual Due: 10/08
Transponder Due: 10/09
Static system Due: 10/09
ELT Due: 10/08
Oxygen Bottle Due: 12/11
@ AirKZ...смотри пример!...как Цесснами торгуют......и вопросы сразу отсутствуют...
Year      1973
Manufacturer      CESSNA
Model      TURBO 337G-P II
Price      US $125,000
Location      Tyler, Texas
Condition      USED
Total Time      2849 Hours
Overhaul      1147 SMOH / 555 STOH / 1147 SMOH
Flight Rules      IFR
Number Of Seats      5
Robertson STOL, Micro Vortex Gen, Garmin GNS 530, VistaNav-WX-GND PX
1973 T337G-P Pressurized, Turbocharged, Robertson STOL Kit, Micro Vortex Generators, Garmin 530, Motion VistaNav Tablet with WX & Ground Proximity, Excellent Avionics package, Excellent Paint and Very Good Interior, Excellent Maintenence History and Records, No Damage History, All Logs, Seller sold out of state business does not need anymore.
Airframe:
2849 TT
Engine Specs:
Contenintal TSIO-360-C
Front 1147 SMOH 555STOH
Rear 1147 SMOH
Prop(s):
173 SOH Front & Rear
Robertson STOL Kit
Avionics/Radios:
Garmin GNS 530
Motion VistaNav with WX and Ground Proximity
Garmin 327 and 320 Transponders
Insight Strikefinder
Icarus Altitude Alert
Monroy ATD-200 Traffic Detector
Garmin GMA 340 Audio w/ 4 Headsets
Bendix/King KX155 Nav/Comms
Bendix/King KY196 Comm
Bendix/King KM64 DME
Cessna 400 Navomatic
Hoskins Fuel Flow
EDM 760 Engine Analyzer
Robertson STOL
Exterior:
Beautiful Overall White with Grey underside and Bold Maroon with Gray Pinstripe scheme
Interior:
Maroon Leather
Inspection Status:
Current Annual
Красивый самолет. Мощный. В полете смотрится солидно, внутри раскошно.
Мне нравится. Дороговат конечно, особенно в ремонте. Но в своем классе того стоит.
Помню , прям на моих глазах у такой Цессны не вылезли шасси. Самолет кружил над аеропортом вырабатывая бензин, на земле его уже ждали две пожарные машины. Потом пилот очень лихо тянул до последнего на минимальной высоте, в последний момент заглушил двигатели( винты остановились горизонтально. Оба!) и заскрепел пузом по бетону. ( а ведь рядом трава была, но если на нее сесть- страховка ремонт не оплатит). Скользил пузом недолго и очень ровно, как буд-то специально на то был расчитан. за ним уже гнались пожарки. После остановки из самолета выскочили и разбежались трое,а  пожарники уже брызгали пену. Хотя огня небыло.
А какой надо процент к цене примерно накидывать, чтобы штатовскую машину доставить к нам?
@Leonid...прирост скорости от убирающихся не значителен!...надо брать с неубирающимся, как на фотах...
@DIR...надо тебе у Zaturы спросить, он точно знает...
😱Значит эта машинка обойдется примерно - 4 550 000 рублей!
Круто! НО сначала надо пережить финансовый кризис в стране! :-/
@DIR...рынок огромный, найти и дешевле можно и не обязательно Цессну этой модели!
[highlight]Manufacturers:[/highlight]
  • Cessna Aircraft
    Beechcraft Aircraft
    Piper Aircraft
    Gulfstream Aircraft
    Learjet Aircraft
    Mooney Aircraft
    Hawker Aircraft
    Dassault Aircraft
    EADS/Socata Aircraft
    Commander Aircraft
    Cirrus Aircraft
    Diamond Aircraft
@AirKZ...с ценой и комплектацией, так и не появляется... :-/
2 ea.     Collins  VHF  nav/com                                   VIR  351   TSO
1 ea.     Collins   DME                                               XX      TSO
1 ea.     Collins  R Nav                                               ANS - 351 TSO
1 ea.     Collins   transponder                                      TDR - 950 TSO
1 ea.     ADF  Collins                                                  650- A     TSO
1 ea.     ADF   KING                                                    KR  87
1 ea.     Collins  marker beacon audiopanel                   AMR  350   TSO
1 ea.     King   Color  radar                                           KWX   56
1 ea.     Altitude  alert                                                 AM   276
1 ea.     King   GPS                                                     KLN   90B     TSO
2 ea.     Bose  noise cancelling headsets
1 ea.     Sigtronics   intercome system                           SPA   400
1 ea.     RMI  indicator
1 ea.     HSI indicator  remote gyro  driven.
1 ea.     Electrical  driven horizon  indicator   Standby..unit
1 ea.     ILS   indicator
!980г\в, наработка планера и двигателей TSIO-360HB - 1380ч. Ремонтов не было, дополнительно установено ПОС крыла и стабилизатра (вздушно-импульсные) Обогрев винта злектрический.
Цена 185К$
Майор, а зачем в топик с конкретным предложением засовывать другие примеры?
Пофлудить?
...@ Vane4ka всегда найдутся индивидумы, которые захотят навязывать свои понятия!
...@ Vane4ka отвечаю на твой вопрос!
...что бы не раздувать тему с один и тем же вопросом!
...жаль что ты не заметил, что и Я то же дал два объявление...по почти такой же Цессне...
...@ Vane4ka...так кто же из нас флудит?...и при этом хочет выглядеть ну что ли праведником...
...и очень плохо, что ты не вразумел, что Я за одно поделился опытом...
...если чел. даёт объявление без цены, без описания товара и без спецификации, закрадаваются мысли вот даже и у тебя @ Vane4ka 😉...что ему это не надо...
...и посмотри как @AirKZ правильно прореагировал...в отличие от тебя...сразу вся инфа - появилась!
...а вот ты @ Vane4ka и впрямь влез не по теме...исправляйся...дружище...
Добрый день.
Мне ваше предложение интересно.
Где сейчас находится самолет и под какой он регистрацией на данный момент?
Владимир
vanosov@elnet.msk.ru
