Продам радиостанция ICOM UV88 двухдиапазонная -=Доставка по РФ БЕСПЛАТНО=-
МиЛ
Буду летать на аэрошюте!
Красноярск
Радиостанция двух диапазонная, новая. Комплектация на фото
Цена 4200р. Доставка по РФ БЕСПЛАТНО
Срок поставки 4 недели
Main function:
VHF / UHF double display double Shouhou, band selection
Support FM radio digital tuning
Scrambling function / voice compression and expansion function
Voice prompt function
The VOX function, rank optional
Emergency alarm function
Full frequency channel mode / program / online programming / manual adjustment
Manual / online electrically adjustable ( signaling frequency, power, sensitivity)
50 groups of CTCSS encoding / decoding,104 groups of CDCSS encoding / decoding
Scan ( multi-function scanning, the priority scan )
Sound control sensitivity adjustable
Emission high ( low ) power adjustable
09squelch grade level
Timeout timer ( TOT )
Frequency direction, frequency difference set
Step frequency5 /6025 /10 /12.5 / 25KHZ
Keyboard lock function
Beep function
Tail elimination function
GENERAL
The frequency range of 1( MHz ) : 136-174( VHF ) / 400-470( UHF ) (more than two bands transmitting and receiving can be);
The launch of 2types: F3E
3channel number:199
4broadband options:25KHz / 12.5KHz
The 5 power supply voltage:7.2VDC2200mAh
The 6 frequency stability: + 2.5ppm
The 7antenna impedance50 ohm
RECEIVE
1:38.550MHz crystals: MF
The sensitivity of the 2:122dBm (12dB SINAD )
3 selective ( wide / narrow ):65dB / 60dB
4:65dB spurious suppression
The 5 audio output power:500mW ( less than 5% )
TRANSMITTER
1emission power: (1)5W / 1W ( VHF ) (2)4W / 1W ( UHF )
Maximum modulation frequency offset:2+ 5KHz ( W + 2.5KHz ) / ( N ) (100%)
Modulation distortion is less than or equal to 5%:3
4:65dB stray radiation
5adjacent channel power:65 / 55dB
6:40dB FM noise
Standard configuration: machine, a belt clip the antenna, a lithium battery, a charger, a, a, a lanyard manual, warranty card, a packing box a.
К сожалению, к авиации эта станция не имеет отношения . И диапазон не тот и модуляция другая. Судя по наличию в ней возможности радиоприема на FM , синтезатор реально перепрограммировать на авиадиапазон, а вот изменить модуляцию уже не просто.
Для пилота АХР самое то,работает и слушает радио FM диапозона,рация автоматически перейдет в режим приема при вызове пилота. 😉
В Красноярске парапланеристы, парамоторщики и дельталётчики используют диапазон VHF (136-174), так что думаю имеет отношение 🙂
