Вот такой самолёт.
S P E C I F I C A T I O N S
SPAN 18' 8"
LENGTH 18' 10"
HEIGHT 5' 5"
ENGINE 1700 - 2180CC
FUEL CAPACITY - STD. 10 GALLONS
FUEL CAPACITY - OPT. 6 GALLONS
EMPTY WEIGHT (No Starter) 520 LBS.
USEFUL LOAD 430 LBS.
GROSS WEIGHT 950 LBS.
WING AREA 84 SQ. FT.
WING LOADING AT GROSS 11.3 LB SQ FT
SEATS 2 TANDEM
P E R F O R M A N C E S
DESIGN LIMIT AT FULL GROSS +/- 4 G's
AEROBATIC LIMIT SOLO W/755 LBS. +/- 6 G's
TAKE OFF DISTANCE 900 FT.
STALL SPEED 45 MPH
LANDING SPEED 58 MPH
MANEUVERING SPEED 115 MPH
CRUISING SPPED AT 75% 140 MPH
VNE 200 MPH
RANGE W/45 MINUTE RESERVE 245 SM
RATE OF CLIMB AT GROSS 500 FPM
http://www.greatplainsas.com/sonerai_ii.html
SPAN 18' 8"
LENGTH 18' 10"
HEIGHT 5' 5"
SEATS 2 TANDEM
STALL SPEED 45 MPH
VNE 200 MPH
28 КБ Просмотры: 165
