Дмитрий Шаповалов (Velocity)
Хвост в самолете лишняя деталь!
- Откуда
- Москва
Прогресс идет и то, что раньше занимало целые вычислительные залы теперь умещается в маленьких копеечных кристаллах dsPIC30F4013.
Это не самый крупный чип этой серии, но возможности отличные 😎
Architecture - 16-bit
CPU Speed (MIPS) - 30
Memory Type - Flash
Program Memory (KB) - 48
RAM Bytes - 2,048
EEPROM - 1024
Temperature Range C -40 to +125
Operating Voltage Range (V) - 2.5 to 5.5
I/O Pins - 30
Pin Count - 40
System Management Features - PBOR, LVD
Internal Oscillator - 7.37 MHz, 512 kHz
nanoWatt Features - Fast Wake/Fast Control
Analog Peripherals - 1-A/D 13x12-bit @ 200(ksps)
CPU Speed in MIPs - 30
CODEC I/F - Yes
CAN (#, type) - 1 CAN
Capture/Compare/PWM Peripherals - 4/4
Timers - 5 x 16-bit 2 x 32-bit
Parallel Port - GPIO
Hardware RTCC - No
DMA - 0
-High-Performance Modified RISC CPU:
-Modified Harvard architecture
-C compiler optimized instruction set architecture
-84 base instructions with flexible addressing modes
-24-bit wide instructions, 16-bit wide data path
-16 x 16-bit working register array
-Up to 30 MIPs operation: - DC to 40 MHz external clock input - Internal FRC input with PLL active (4x, 8x, 16x) - 4 MHz-10 MHz oscillator input with PLL active (4x, 8x, 16x) - 10 MHz - 20 MHz oscillator input in HS/2 or HS/3 with PLL active (4x, 8x, 16x)
-Peripheral and External interrupt sources
-8 user selectable priority levels for each interrupt
-4 processor exceptions and software traps
-Primary and Alternate interrupt Vector Tables DSP Engine Features:
-Modulo and Bit-Reversed Addressing modes
-Two, 40-bit wide accumulators with optional saturation logic
-17-bit x 17-bit single cycle hardware fractional/ integer multiplier
-Single cycle Multiply-Accumulate (MAC) operation
-40-stage Barrel Shifter
-Dual data fetch Peripheral Features:
-High current sink/source I/O pins: 25 mA/25 mA
-Optionally pair up 16-bit timers into 32-bit timer modules
-3-wire SPI™ modules (supports 4 Frame modes)
-I2C™ module supports Multi-Master/Slave mode and 7-bit/10-bit addressing
-Addressable UART modules with FIFO buffers and selectable pins
-Data Converter Interface (DCI) supports common audio Codec protocols, including I2S and AC’97 Analog Features:
-12-bit 200 Ksps Analog-to-Digital Converter (A/D)
-A/D Conversion available during Sleep and Idle
-1 Sample/Hold
-Multiple Conversion Sequencing Options Special Microcontroller Features:
-Enhanced Flash program memory: - 10,000 erase/write cycle (min.) for industrial temperature range, 100K (typical)
-Data EEPROM memory: - 100,000 erase/write cycle (min.) for industrial temperature range, 1M (typical)
-Self-reprogrammable under software control
-Power-on Reset (POR), Power-up Timer (PWRT) and Oscillator Start-up Timer (OST)
-Flexible Watchdog Timer (WDT) with on-chip low power RC oscillator for reliable operation
-Fail-Safe clock monitor operation
-Detects clock failure and switches to on-chip low power RC oscillator
-Programmable code protection
-In-Circuit Serial Programming™ (ICSP™)
-Programmable Brown-out Detection and Reset generation
-Selectable Power Management modes - Sleep, Idle and Alternate
-Clock modes CMOS Technology:
-Low power, high speed Flash technology
-Wide operating voltage range (2.5V to 5.5V)
-Industrial and Extended temperature ranges
-Low power consumption
Memory Type - Flash
RAM Bytes - 2,048
EEPROM - 1024
I/O Pins - 30
Pin Count - 40
CODEC I/F - Yes
Hardware RTCC - No
DMA - 0
-1 Sample/Hold
