EMS XTREME продаю новый.
Irvin
Я люблю небо!
Продаю интегральный прибор мониторинга двигателя EMS XTREME
(80 мм, MGL Avionics, ЮАР)  - 53 000 р. В Москве, новый.
    59,7 КБ · Просмотры: 240
датчики и сенсоры в комплекте?
можете в личку телефон написать?
Engine Monitoring:
• 1x Engine RPM display
• 1x Rotor RPM display (MGL Avionics RDAC-XF / MAP required)
• 1x Manifold pressure display (MGL Avionics RDAC-XF MAP required)
• 1x Oil pressure display • 1x Oil temperature display
• 2x Auxiliary analog channel displays (Pressure,Temperature or Current)
• 12 Channel EGT/CHT display
• 2x Fuel Flow displays (Dual fuel flow requires the RDAC-XF / MAP)
• 2x Fuel Level displays
• 1x Fuel pressure display (MGL Avionics RDAC-XF / MAP required)
• 1x Current input (MGL Avionics RDAC-XF / MAP required)
• Special Rotax 912/914 engine monitor mode utilizing the standard built in Rotax NTC CHT probes
• Special Rotax 912IS mode (MGL Avionics RDAC CAN required)
• Programmable maintenance timer for scheduled routine engine maintenance
• User settable Hobbs meter (password protected)
• Fuel range / endurance calculated from GPS ground speed. (Requires external RS232 GPS receiver)
• Supply Voltage display
• OAT (Outside Air Temperature) display
• Engine leaning feature
• Stopwatch timer
• Automatic / Manual flight timer
• RTC (Real Time Clock)
• CO Monitor. (CO Guardian CO detector required)
• The engine display screen is automatically configured to optimize screen space depending on what engine parameters has been selected
