Гарнитуры.
gsg1960
Украина
Подскажите какая из двух лучше. Будет интересно знать мнение знатоков этого дела. Заранее благодарен.
1.Aviation Headset Pilot ASA AIR CLASSICS HEADSET HS-1A with Flex Boom.  Excellent condition, lightly used!!
Good communications are essential for a successful flight. ASA provides this in the HS-1A with the most advanced technology, maximum comfort, high-quality components, and sleek look — all for a reasonable price!  Protect your hearing, don’t miss any radio calls, and be certain your transmissions are heard with this feature-rich, value-priced headset.
HS-1A Headset features
Earcups of high-density acoustic foam for best passive noise attenuation
Adjustable boom mic
High fidelity speakers for clear, natural sound
Electret, noise-canceling microphone reduces background noise and allows clearest voice transmission
Gold-plated microphone and headphone plugs ensure best connection and resist corrosion
High-grade, multi-strand wire improves cable life
Stereo/mono capability
Large, dual controls for quick, easy volume adjustment of each ear
Microphone muff
Adjustable headband with easy thumb screws eliminates "hot spots" and accommodates eyeglasses and any head size
Quality foam ear seals and light weight add to overall comfort
Sleek, all-Black design with ASA silver wings tastefully silk-screened on each  ear cup
Sturdy and reliable - yet reasonably priced for maximum value.
    130,5 КБ · Просмотры: 127
2. Professional Echelon Telex Pilot's Headset 300535 Aviation Flight Pilot Head Set
This full cushion aviation headset is in great condition, as you can see from the pictures.  It comes with the User Instructions.  Telex Echelon Headset is stamped with:  Catalog #300535-000.  There are no rips or tears on these, and the cushioned ear seals are in excellent shape as well.  The Telex Echelon Catalog #300535-000 provides an impressive passive noise protection and a top-quality noise canceling electric microphone for clear, reliable communications. The Telex Echelon features a low-profile headband for even weight distribution plus patented Comfort Cam technology, a three-click tension adjustment system for a custom fit.  Special earpieces with foam ear-seals pivot two ways to conform to any wearer while detent sliders adjust the headband, making the Telex Echelon a comfortable headset for any flight.
    53,8 КБ · Просмотры: 127
Добавлю еще вариант №-3
Genuine Faro G2 Aviation / Pilot Headset - Brand New - $189
MP3/Radio/iPad/iPod 3.5mm Input
    30 КБ · Просмотры: 138
Нашел...которая вклеивается... по честному 20$ комиссии, и на каждый адрес..
