КИТ BD-5
Конечно же секретов быть не может.
Я только готовлюсь к приобретению у Олега.
Нужна в первую очередь оценка своих возможностей для сборки.А посему жду документацию от данного товарища.
Если Вы уже собрали или только хотите купить,то мне очнь было бы интересно,какой двигатель собираетесь ставить?
На английском.
Builder Assistance Option 1: Basic Quickbuild Features
The following listed sub-assemblies are made ready for installation:
1. FU35 Spreader Bar assembly.
2. Nose gear box.
3. FU12 Tee Splice.
4. FU137/138 Wing Fillet and FU141/142 Rib assembly.
5. LG97 M.L.G. Wheel Well Access Plate (2) assembly.
6. LG34 Nose Gear and Retract Mechanism assembly.
7. LG72 Nose Gear assembly.
8. LG73 Nose Gear Door assembly.
9. LG80 M.L.G. Pulley assembly.
10. LG132 M.L.G. Cable Pulley, R.H., assembly.
11. LG133 M.L.G. Cable Pulley, L.H., assembly.
12. CR33/34 Rudder Pedal/Brake assembly.
13. CR31 Rudder Stop assembly.
14. CR35 Rudder Evener System.
15. LG183 Landing Gear Handle assembly.
16. CA7 Stick and Stick Box assembly.
17. CA9 Aileron Torque Tube assembly.
18. CA23/24 Aileron Torque Tube Bracket assembly.
19. CA15 Aileron Crossover Torque Tube assembly.
20. CA13 Control Rod assembly (2).
21. CHS11/12 Aft H.S. Pulley Mount assembly.
22. Electric Trim System assembly.
23. CR4 Rudder Pulley Mount assembly.
24. CC16 Foreword Pivot Arm assembly (2).
25. CC25/FU7 Aft Pivot Arm assembly.
26. Basic cockpit floors and channels.
27. Drive support sheetmetal structure.
The following items are located and drilled in preparation for final closing or assembly. (May include dimpling,
countersinking, deburring, installation of nutplates, etc. as needed.)
1. Nose gear box to fuselage”
Includes:
Pitot tube.
LG73 nose gear door to fuselage.
Basic cockpit floor support structure.
Heel skid plates to nose gear box.
2. Upper console support angles.
3. Shoulder harness/LG89A support structure.
4. Engine compartment door frames.
5. FU23/24 Longerons
6. Aft fuselage stiffeners and bulkheads.
7. NACA jet scoops.
8. Engine compartment cooling scoops.
9. Engine compartment floor and FU1 angle.
10. Forward H.S. Pulley Mount assembly.
11. Vertical stabilizer attachment bulkheads.
12. Rudder pulley assembly to vertical stabilizer.
13. CR12 forward rudder conduit support.
14. CR13 aft rudder conduit support.
15. CR7 Rudder Horn to rudder.
16. Aft horizontal stabilizer pulley assembly.
17. H.S. center spar pivot weldment to fuselage.
18. Fit H.S. center spar to pivot weldment.
19. Electric trim assembly.
20. Drive support structure to FU6 Bulkhead.
21. FU99 Center Spar to fuselage.
Builder Assistance Option 2: Advanced Quickbuild Features
Fuselage partially assembled to “On the Gear” stage. Includes all the items listed in Builder Assistance
Option 1. Includes installation or assembly of the following:
Chapter 1: FUSELAGE
1. Nose gear box.
2. FU21/22 Stiffeners.
3. FU29/30 Doublers.
4. FU17/18 Longerons.
5. FU23/24 Longerons.
6. Aft fuselage vertical closure stiffeners.
Chapter 2: VERTICAL STABILIZER and RUDDER
2. Locate and drill vertical stabilizer to support structure.
Chapter 3: WINGS
1. Wing spars honed and fitted to center spar.
2. Wings drilled to center spar.
3. Taper ream wing locating holes.
Chapter 4: FLAP and AILERONS
1. Fit flap and ailerons to wing rear spar.
2. Drill and net trim flap and aileron trailing edge.
Chapter 5: HORIZONTAL STABILATOR
1. H.S. center spar and pivot mechanism to fuselage.
2. Aft fuselage bulkheads.
3. Locate and drill H.S.’s to H.S. center spar.
Chapter 6: LANDING GEAR
1. Install and rig nose retract assembly.
2. Center spar to fuselage.
3. Main landing gear retract mechanism.
4. LG80 M.L.G. Pulley assembly.
5. M.L.G. Crossover Pulleys.
Chapter 7: CONTROL SYSTEM
1. Assembled on nose gear box:
Landing gear actuating handle.
Rudder pedals.
Rudder evener system.
Brake master cylinders.
Brake fluid reservoir.
Landing gear cable pulleys.
Rudder pedal outboard mounts.
2. Landing gear cables.
3. Stick box assembly with CA9 Aileron Torque Tube to fuselage.
4. CA21 Bulkhead.
5. CA23/24 Aileron Torque Tube Bracket assemblies to fuselage.
6. H.S. forward pulley system.
7. H.S. aft pulley.
8. Electric trim system
Chapter 8: COCKPIT and CANOPY CONSTRUCTION
1. Windshield attachment structure.
2. Basic cockpit floor.
3. Upper console attachment angles.
Chapter 10: POWERPLANT
1. Basic engine support structure.
2. NACA scoops and inlet ramps.
3. Extractor box.
4. Drive support to FU6 Bulkhead.
5. Drive system.
6. FU66 Bulkheads.
Олег извини!!!
Просмотрев почту,я не понял,в каком формате документы.
Андрей
rar-файл, разархивированный документ pdf, письмо должно было прийти из 7 частей, 45 мегов.
у меня джет вариант у Олега В!
СОбирать не очень сложно так как он весь на вытяжных заклепках!
Олег,уко мне пришли буковки циферки в письмах.
Как привести в нормальный вид
Олег прости пожалуйста.
Я под запретом.Объяснить не могу по многим причинам.
Покупка несостоится и вообще  врятли смогу покупать .
Еще раз извини.
Андрей
А вообще он где нибудь летает, есть видео, ЛТХ, фото построенных аппаратов,?
Олег я Вам звонил по поводу Ваших BD5-ых, надо посмотреть фотки китов, а потом и воочию, возможно после я их приобрету. У самого есть авиатика двухместная, проходит регистрацию, потом будем курсантов обучать, а киты нужны для себя больно он мне понравился. Мой номер 89035345667 Алан
http://www.youtube.com/watch?v=18g8g5oJPRc&feature=related
Это все понятно, я Вам в личку написал, ответа пока не получил, какой двигатель ставить. если рассматривать винтовой вариант, фото КИТ-а можно на электронку: govgalenko@mail.vanino.ru, я имел в виду в России летающие есть?
В России летающих нет, в винтовом варианте (версия B) ставили   двигатели от снегоходов, Хирты, Ротаксы  и заканчивая авиаконверсиями Хонды и Субару.
Телефон продавца кто нибудь знает?
Вам чей тел нужен я не продаю бд 5 продает другой человек откройте форум продаж там есть тема по продаже или напишите ему лично!Я кстати скинул Вам телефон
