Вот тоже моторчики б/у покрупнее продаются, может кому интересно будет. 12 штук с хорошим ресурсом. Ниже все данные, сорри лень переводить.
First off these are not airboat engines & have never been airboat engines!
Second I own a Aircraft Salvage/ used parts company & have been doing this for sometime now.
Third if you have a question or concern call or email me. I will do my best to help answer questions, I do this for a living. The aviation world is very small so word travels fast & you get nowhere by screwing people.
I have 12 IO & O 540 Engines For Sale with Low to mid time. I have a few run out cores also. Will list a few below, but you can call or email me if you need more info or need something not listed.
I have a pair of O 540 A1D5's One has 8 SMOH by Signature, other has 125 SMOH by Tropical Airpower. Narrow Decks, Complete Mags, Carb, Starter. Not lighting hole cranks, can be converted to IO 540 C4B5's. Both engines will have fresh IRAN done on the cylinders.
I have a pair of IO 540 c4B5's with 800 SMOH by Certified Engines, Both engines will have fresh IRAN done on the cylinders. These engines can be sold with or without accessories. Narrow Deck's
Another IO 540 C4B5, 1000 SMOH by Certified Engines, 6 fresh overhauled cylinders, wide deck.
Have a few more that are normal runouts..... (IO 540 c4B5's)
I also have a O 540 A1A5 that has 1700 TTSN, engine had a fresh overhaul but was not documented. I sent the engine to Flightline Engines to have the cylinders removed, inspect the engine & document the engine. Will not be signed off as overhauled, but will know whats inside & what was done. Reassemble, IRAN cylinders, sign off for cylinders. . No Accessories, but priced to sell.
Flagler Air Exchange, Inc PH: 386-437-5729
241 Old Moody Blvd
Palm Coast, FL 32164
