Продается французское крыло - Ipsos-19
Alex Fink
Летать я люблю все таки больше!
Изготовленно фирмой La Mouette. Налет - 20 мин.. 150т.руб.
тел.  9452945     Петербург.
какая грузоподъёмность, сколько квадратов? дельтаплан или крыло для дельталёта? фото пожалуйста.
IPSOS 19
24 M.P.H to 60 M.P.H
This wing possesses a large wing surface of 19 square meters with the porportion of double surface which does not exceed 30%.
You'll find this handy for lifting heavy loads from short or unimproved fields.
The IPSOS 19 is perfect to pin-point those marginal landing stips, at low speed, without risk of sinking or stalls; its use in the mountain will make you appreciate your choice !
The IPSOS 19 is great for training beginners and for specific activities such as towing hang gliders as well as landing in difficult areas. The design of the floating keel provides an exceptional manoeuverability for a wing of this wingspan : you need 2 seconds to reverse a turn of 45° at 45° !
the IPSOS 19 is easy to assembly thanks to its external cross-bar and a reduced number of upper-surface battens. This is the wing you will wnat to take on your vacations ! The assembly time is 6 minutes...
Its cylindrical tubes are in Dural 2017 or 7075 which are certified for aircraft quality and tested by the Foucault current method and possess essential advantage for your safety.
Surface (mІ)      18.50
Weight (kg)      43
Span (m)      10.40
Ultimate load (unbroken) (kg)      2400 kg
Number of removable battens      17
Nose angle (°)      130
    122,9 КБ · Просмотры: 135
    40 КБ · Просмотры: 163
