ПРОДАЖА РАПТОР 178
Я НЕ СПЕЦ ПО ФООТ. КОЛЛЕГИ ШИРОКО РЕКЛАМИРОВАЛИ...РАПТОР 178... ПОСМОТРИТЕ НА ФОРУМЕ. СФОТОГРАФИРУЕМ В ПОНЕД. ПОСТАВИМ НА СТЕНД. КИТАЙ НО НА ВИД  НЕ ХУЖЕ ИТАЛИИ А ГЛУШИТЕЛЬ ЛУЧШЕ СИМОНИНИ 2 ЭВО.ОТЧИТАЕМСЯПО ИСПЫТАНИЯМ. ЭТИ МОТОРЫ БУДУТ ПОКАЗАНЫ С 6-8 НА АЭРОДРОМЕ псебай
Интересный движок - дизель
Raptor 105
Horsepower      105 HP  (78 kW)  @ 2500 Prop RPM,   2875 Engine RPM Continous power
Configuration      Turbo diesel, 4 cylinder in-line, 4 stroke cycle, Liquid cooled, Propellor speed reduced
Features
Diesel Fuel Injection
     Raptor designed common rail fuel contoller, 1800 bar (26100 psi) operating pressure
Propellor Speed Reduction
     Link plate style reduction unit,  1.148:1  Ratio
Fuel
Type
     Diesel #2 (autodiesel), Jet A, JP-8, most biodiesel. Different approved fuels may be mixed in tank in any proportions.
Dimensions
Length      22.50 inches   571.5 mm
Width      22.25 inches   565.2 mm
Height
     16.50 inches   419.1 mm
Bore
     2.972 inches    75.5 mm
Stroke
     3.327 inches    84.5 mm
Displacement
     92 cubic inches ( 1.55 Liter )
Weight
     179 lbs  81 kg (see separate heading)
Capacities
Oil Type
     Mobil Delvac I
Oil Quantity
     4 Quarts,  3.78 liter, standard (5 qts., 4.75 liter, w/optional 2nd filter)
Coolant Type
     50/50 ethylene glycol/water
Replaceable Items
Oil
     Change every 50 hours or 6 months (whichever comes first)
Filter
     Change with oil
Fuel filter
     Change every 200 hrs. (300 hrs. optional dual filters)
Glow plugs
     No scheduled replacement- replace as needed
Coolant
     No scheduled replacement - replace as needed
TBO
Interval
     1500 Hours Initial
Service
     There is no regularly scheduled mechanical service required.
Weight
Dry
     179 lbs   81 kg
Расскажите о нем и о стоимости, думаю, что всех заинтересует.
    43 КБ · Просмотры: 120
