Стрелец
Никогда не поздно иметь Счастливое детство
- Откуда
- Липецкая область, г. Усмань
Нет не в Москве, от Вас 700 км! Но за приглашение большое Спасибо! Можете дать свою почту есть вопросы!
По поводу "Чуть-чуть" можно посмотреть вот здесь.., наверное:Спасибо за информацию, теперь вот как определить это Чуть-чуть? Ну тут конечно понятно, что по виду, ну и вмятинки не большие!
Cessna Aircraft Company. Single Engine. Structural Repair Manuel. Wing Damage Classification.
2. Wing Skin Damage Criteria
A. Negligible damage: Any smooth dents in the wing skin that are not more than 0.030 inch below
contour and can be circumscribed with a 2 inch diameter circle that have no evidence of skin tears,
cracks, or skin penetrations - which are not stress wrinkles and do not interfere with internal structure
of mechanism - constitute negligible damage; and rework is considered cosmetic.
B. Repairable damage: Dents or dings deeper and/or larger than specified above must be repaired.
Skin tears, cracks or penetrations must be repaired. Dings that include understructure (ribs, frames
and spars) must be repaired by reforming or removal and replacement of the damaged member or
damaged are. Reevaluation of the skin after repair of the understructure will determine if the skin
damage is negligible, repairable or requires replacement.
C. Damage Necessitating Replacement Of Parts: If a skin is badly damaged, repair must be made by
replacing an entire skin panel from one structural member to the next. Repair seams must be made
to lie along structural members and each seam must be made exactly the same in regard to rivet size,
spacing and pattern as themanufactured seams at the edges of the original sheet. If themanufactured
seams are different, the stronger must be copied. If the repair ends at a structural member where
no seam is used, enough repair panel must be used to allow an extra row of staggered rivets, with
sufficient edge margin, to be installed.
У этого самолета, несмотря на его низкую стоимость, очень хорошие привязные ремни в кабине... :и еще один настоящий самолет,достойный внимания по человечьей цене 6900 евро!! Соката Минерва
http://www.planecheck.com/aspdet.asp?nr=23956
http://www.youtube.com/watch?v=S4k8J4cDeJ0&feature=youtu.be
согласен,Олег)самолет что надо!) :~)Мы собрали и облетали нашу Сокату. Спасибо большое Тадэуш и Олег.
Отличный самолёт!!!
