- Москва, Россия
Как вам это произведение искусства. Германского разлива.
Вот данные:
Engine type: 4 stroke, 4 cylinder, 16 valve, DOHC,
MPI(Multi Point electric fuel Injection),
Engine displacement: 1597
Bore & stroke (MM): 80[ch215]79.5
Compression ratio: 10.5:1
Rated power(HP/r/min):160±3/8000
Max torque (Nm/r/min):150±3/4200
Idle rotate speed(r/min): 800±25
Start system: Electric start
Spark plug model:RC8YC
Ignition control:No distributor,electric control,
direct ignition
Chain drive: Variable valve timing(VVT)
Minimum fuel consumption: 15L/h
Oil capacity (L): 4.2
Fuel quality(RON):[ch8805]93#grade gasoline
Oil quality: [ch8805]SJ grade
Cooling system: Inside Closed-loop water cooled
Max fuel pressure(bar):3.8
Net weight(kg):93
Overall Dimension(L*W*H)(mm):650[ch215]580[ch215]600
Emission g/km(EU):CO[ch8804]1.0 HC[ch8804]0.1 NOx[ch8804]0.08
Вот данные:
direct ignition
Net weight(kg):93
