Продам р/ст.Midland 70-1336В
Продам р/ст.Midland 70-1336В, цифровая,исправная,чисто самурайской сборки,программируется.
Может кому надо для личного пользования.
Прошу 2,5т.р.+доставка.
Тех.данные только на английском:
GENERAL INFORMATION
The 70-1336 Midland 8-Channel Wide Band transceivers are programmable frequency-synthesized two-way mobile radios that operate in the high-band VHF frequency range. They are programmable for up to eight channels.
The 70-1336 is designed to operate within either of two frequency ranges: 136-160 MHz (A-Band), or 150-174 MHz (B-Band). Transmit RF power is adjustable for 15-30 Watts.
SPECIFICATIONS
Refer to EIA-152-C, EIA/TIA-204-D, E1A-220-B, and DOC RSS-119 for standard of performance and method of measurement.
GENERAL
OPERATING FREQUENCY RANGE:
A-Band: 136—160 MHz B-Band: 150—174 MHz
CHANNEL SEPARATION: 24 MHz
CHANNEL SPACING: 30kHz
CHANNEL STEPPING: 2.5kHz
CHANNEL CAPACITY: Programmable for up to eight channels
POWER SUPPLY: 13.6 V DC negative to ground
CURRENT DRAIN:
Transmit (at 30W): 8.0 A
Receive (@ rated audio): 2.0 A
Standby (std, varies with options): 400 mA
OPERATING TEMPERATURE: -30° C + 60° C
DIMENSIONS (H x W x D): 2 x 7 x 87/8 in (50 x 178 x 225 mm) WEIGHT: 2.5 kg
ТRANSMITTER
RF POWER OUTPUT (adjustable): 15—30 W
FREQUENCY STABILITY: ±0.0005% (-30°C + 60° C)
MODULATION (FOR 100% AT 1000 Hz): 16KOF3E ±5.0 kHz @ 25/30 kHz
BANDWIDTH: 24 MHz without retuning
SPURIOUS AND HARMONICS: -61 dB
FM HUM AND NOISE: -50 dB
AUDIO RESPONSE: per EIA and DOC specifications
AUDIO DISTORTION (±3 kHz deviation): Less than 3% @ 1 kHz
OUTPUT IMPEDANCE: 50 Ohm
RECEIVER
FREQUENCY STABILITY: ±0.0005% (-30° C + 60° C)
SENSITIVITY:
12dBSINAD: 0.30 /W
20 dB Quieting: 0.5 [uV
SELECTIVITY: -80 dB @ ±30 kHz
ACCEPTABLE RADIO FREQUENCY ±3.5 kHz DISPLACEMENT:
SPURIOUS REJECTION: -80 dB
INTERMODULATION: -78 dB
SQUELCH SENSITIVITY: 0.2 uV maximum
AUDIO OUTPUT:
Internal Speaker: 2 W @ less than 3% distortion @ 8 Q
External Speaker: 5 W @ less than 3% distortion @ 3.2 Q
INPUT IMPEDANCE: 50 Ohm
CTCSS/DCS
OPERATING TEMPERATURE RANGE: -30° C — +60° C
CTCSS TONES: All EIA tones from 67.0 Hz to 250.3 Hz, plus 97.4 Hz
DCS CODES: All codes from 000 to 777, normal and invert
ENCODE TONE/DCS MODULATION LEVEL: 500 Hz — 1000 Hz deviation
ENCODER RESPONSE TIME: CTCSS/DCS 50 ms max
ENCODER TONE DISTORTION (67 Hz—250.3): 3% max
TONE/SQUELCH OPENING SINAD: 8 dB max
HUM AND NOISE: 32 dB
DECODER RESPONSE TIME:
CTCSS: 200 ms max (for tones above 100 Hz)
DCS: 324 ms max
С уважением. [smiley=fly2.gif]
    43,5 КБ · Просмотры: 174
    34,3 КБ · Просмотры: 175
Здравствуйте.
Радиостанцию продали?
Здравствуйте.Р/ст. в наличии.
К ней в комплекте еще имеется рабочая портативная р/ст.Midland 70-156-16В, название оно под зацепом для кармана(также самураевской сборки),только без аккумуляторов,т.е. в аккумуляторном корпусе нет "таблеток".
Если интересует,то +1т.р. к верхней сумме(все станции профессиональные).
С уважением.Самарская область.
    30,2 КБ · Просмотры: 186
    32,3 КБ · Просмотры: 163
Есть интерес.Состояние рабочее?Отпишите пожалуйста в личку.Если не продана,наверное в резерв.Какого года выпуска?
Так они же не авиационного диапозона... :-[
:craZy
