M
Master
Спецификация:
Length: Frame 16 ft., Overall 20 ft. Width: 72 in., Height: 84 in.
Rotor Diameter: Main 19.5 ft., Tail 40 in.
Empty Weight XE: 298 lb
Empty Weight XEL: 312 lb
Gross Weight: 610 lbs
Useful (Pilot) Load: 240 lbs.
Fuel Capacity XE: 12 US gallons
Fuel Capacity XEL: 5 US gallons (as required by FAA Part 103, Ultralight Regulations)
Engine: Compact Radial Engines MZ202, 2 cylinder, 2 stroke, rated 64 HP (45kW)
Electrical System: 12 volt DC battery, starter, 180 watt alternator
Rotor Speeds: Main 520 rpm, Tail 2500 rpm
Fuel Flow at Cruise: Approximately 4 U.S. Gallons per hour
Flight Duration XE: Approx. 140 minutes depending on conditions, loading, speed, etc.
Flight Duration XEL: Approx. 60 minutes depending on conditions, loading, speed, etc.
Performance: Hover in ground effect: 8,000 ft. (estimated)
Hover out of ground effect: 6,500 ft. (estimated)
Max Speed: 75 MPH
The FAA has ruled that the maximum speed of 63 mph normally applied to fixed wing ultralights does not apply to helicopters due to their unique power curve.
The FAA increases the weight limit of ultralights to 314 lb for float equipped aircraft. The 312 lb empty weight of the float equipped XEL fits into the ultralight class
Max Speed: 75 MPH
