Предлагаю самолеты из Америки
Появился такой красавец.
VANS RV-8 2006 • $84,000
305 TT, 255 prop, 1130 SMOH, O-320, EFIS, Dynon EMS, KLN-90B, GTX-327, IC-A200, elec trim, 3/14 annual, Shadow Grey Leather Seats and Trim, Garmin 296 GPS (Color Panel Mount), FlightCOM 2 Place. Note: Wired for GPS indicator & Cutout for iPad Mini. This plane is great and a joy to fly. It cruses straight and moves along nicely, burns 7gph at 162kts. New cylinder and overhauled carb 0hrs ago..all logs and the builder log as well as all schematics.
    1,7 КБ · Просмотры: 178
Есть и такой красавец:
1976 CESSNA-172 180 HP • $62,000
HP lyc 0360. 7071 TTA / 743 SMOH. Last annual 9/13/13. King Radios. Very nice interior, paint fair.
    56,8 КБ · Просмотры: 185
И такой:
CESSNA 172K TAILDRAGGER STOL $62,500
1969 Cessna 172K with Bolen Tailwheel conversion. airframe TT: 4055, Engine time is 490 hrs since factory Lycoming overhaul. Lycoming 0320 E2D. All logs since new Horton STOL kit. climb prop. Reiff engine pre heater. Hangared, Clean paint job and interior. Pair of King KX170b with glideslope, ADF, DME, King Audio panel with 3 lt marker beacon, King Txp w/alt enc. Scott 3200 tailwheel with 700x6 tires on the mains. Ski rigging. Annual inspection good til 8/14
    42,8 КБ · Просмотры: 175
Господа простите слегка перепутал описания самолётов при выкладывании :STUPID
Первая С 172 с хвостовым колёсом 1969 г.р., а вторая 1976 г.р.
И ещё появился вот такая красавица:
CARDINAL C177 • $48,000
Total Aircraft time 3532. Lycoming O-320E2D Ram 160 HP STC, TTSMOH 1247.96 Propeller TTSMOH 1281.97 Radios King KX170B Nav/Com, Collins Audio Panelwith Marker beacons, King KX155 Digital Nav/com, KT76 transponder Paint and interior are a 7, Clean well maintained Always Hangared
    62,6 КБ · Просмотры: 207
ZENITH 701 • $43,000
2011 zenith stohl 701 with 100 hpcorvair engine 260 hr.. 1000 fpm climb @ 50 mph cruise @ 90 mph.FUEL burn during cruise 3.8 .Full power 4.2 gph on avgas.new tires very clean has full instruments 496 garmingps with all extras, new interior a great trainer or everyday flyer.10 gal fuel each wing 17 usable can fly 3.5 hrs,66 in warp drive ground adj prop,
И такой:
KITFOX VIXEN • $48,000 • 1999 Vixen.
Rotax 912 UL 80 HP engine, 590 hours. Wing fabric and engine need some work ! King KY97A radios, King KT76A mode C trnspndr. vacuum attitude, turn/bank, cyl head and exh temp. gauge, Airspeed indicator, Adj pedals, full flaps and electric trim. Grove main landing gear. Ballistic Recovery System, Whelen strobes, folding wings. ELT. 26 gal fuel tanks. cruise at 100 mph
    84,8 КБ · Просмотры: 178
Хороший вариант.
Maule MX6 235  1988г.ТТAF and Eng. 800ч в отличном состоянии,колеса тундра,укороченного взлёта и посадки.Мотор Lycoming O540 B4B5 235л.с.$105,000
    55,8 КБ · Просмотры: 216
