Нет, смысла ставить турбулизаторы на "лобастый" и толстый профиль типа Р-III смысла нет.
A22 FoxBat
I recently installed a set of your VGS on my A22valor--( Fox Bat ) N708 FP 80 hp
this airplane is an awesome performer stock and i could solo fly it at 29 mph with full flap
i in stalled the full set wing and tail + some in front of the trim tab as it is not strong enough to trim at full flap
results
trim tab will neutralize controls with 1 noch of flap a slight improvement
i can slow fly it dow the run way @ 25 a 4 mph improvement \( Note at 20 its on the peg ) + the high angle may be affecting the accuracy ??
speed @ 4800- 86 mph no change
@5000 -90mph a gain of 2 mph
@5200- 100 a gain of 4 mph
@wot 5700 - 104 a loss of 2 ???? going to try that again
calm air take off 100 ft a gain of 50 ft
rate of climb 900 ft min before no change noted as of yet
note the flapperons are set at 1.5deg neg to gane speed which lessons the flap angle
this is just preliminary as it was breezy one time, 11 gusting to 15, and calm the next time
the most noticeable thing was how it felt in rough air much more docile felt like a heaver aircraft ( i dont like getting tossed around in rough air ) 100% improvement
i wasent expecting that and still dont understand it the vallor has a very fat wing and may bee the gusts were causing momentary stalls i dont know ????
down final felt really solid even at a slower speed
it hangs on longer on landing so the actual tuchdown is slower thus the landing roll is much shorter like 25% or more
over all good bang for the buck the install took about 2.5 hrs after i got started dont put it off just do it
Regards Arthur
ps i own 8 aircraft from a gyrocopter to a jet
and this is my all time favorite aircraft now with the VGS ITS EVEN BETTER
