Max. take off weight: 450 kg
[smiley=evil.gif] [smiley=evil.gif] [smiley=evil.gif]
[highlight]№0033[/highlight]
Aircraft Manufacturer: TL ULTRALIGHT
Model: [highlight]TL-2000 STING CARBON[/highlight]
Min speed: 35 kt 40 mph 65 kmh
Cruise speed: 130 kt 149 mph 240 kmh
Vne: 165 kt 190 mph 305 kmh
Climb ratio: 1600 ft/min | 8 m/s
Glide ratio: 16:1
Max. take off weight: [highlight]450 kg [/highlight]| 992 lbs
Empty weight: [highlight]275 kg [/highlight]| 606 lbs
Engine: ROTAX 912, 912 S or 914
www.tl-ultralight.cz/
    16,4 КБ · Просмотры: 262
[highlight]№0034[/highlight]
Aircraft Manufacturer: Vol Mediterrani S.L.
Model: [highlight]VM-1 Esqual[/highlight]
Min speed: 35 kt 40 mph 64 kmh
Cruise speed: 135 kt 155 mph 250 kmh
Vne: 173 kt 199 mph 320 kmh
Climb ratio: 1800 ft/min | 9 m/s
Glide ratio: 1:19
Take off distance over 50ft (15m) obstacle: 310 ft | 95 m
Landing distance over 50ft (15m) obstacle: 310 ft | 95 m
Empty weight: [highlight]270 kg [/highlight]| 595 lbs
Engine: Rotax 912 ULS
Other information:
This photo was taken by Key Publishings Duncan Cubitt, during an air-to-air photo sortie for Todays Pilot magazine. The magazines editor, Dave Unwin, is seen here flying the Esqual nearest the camera plane, and a full flight test report will appear in issue 29 of Todays Pilot, on sale Feb 03. Visit the Todays Pilot web site at www.todayspilot.co.uk
www.esqual.com
    17,6 КБ · Просмотры: 273
[highlight]№0010[/highlight]
Aircraft Manufacturer: Aerostyle (Aerosport Ltd in US)
Model: [highlight]Breezer[/highlight]
Cruise speed: 108 kt 124 mph 200 kmh
Vne: 132 kt 152 mph 245 kmh
Climb ratio: 1000 ft/min | 5.1 m/s
Max. take off weight: [highlight]450 kg[/highlight] | 992 lbs
Empty weight: [highlight]295 kg [/highlight]| 650 lbs
Engine: BMW - Take Off/Rotax, 80-100 hp
Other information:
With the engine choice contrary to many other manufacturers another path was taken: We selected a modified BMW fuel injection engine, which has its origin in the building of motorcycles. This engine of in the UL scene admitted Trike manufacturer "Take off" reequipped. The special characteristics of this engine generation are:
- standard fuel injection system
- catalyst optionally possible
- smaller consumption
- better launch characteristics
- favorable mass production technology
- no carburetor icing
The engine in aerostyle Breezer can convince also by its calm, strong run, as well as its pleasant clay/tone With a view under the Cowling immediately the clear and low-maintenance installation of the engine as well as the associated aggregates is noticeable.
Since however many ultralight aircraft prefer the Rotax 912, in 2001 a Aerostyle Breezer was equipped with a Rotax 912 S and certified. Other engine concepts are at present in the development, and/or in planning - let surprise itself!
www.aerostyle-gmbh.de
Среди возможных движков на этот самолет и Жук значится:
http://www.aerostyle-gmbh.de/kategorie5/00000095e90ebfd02/index.html
А что касаемо BD-5, то он никоим образом в данную категорию не входит. При массе до 450 кг микролайт должен быть двухместным, а скоростть сваливания в посадочной конфигурации при неработающем двигателе (или на малом газу), не должна превышать 65км/ч.
В ряде стран (прежде всего Франции и Германии) при установке БПС полетная масса может составлять 472.5кг. Это позволяет увеличить полезную нагрузку на 12-14кг.
Однако такие самолеты, как например Evektor, Sting, возможно CTSW, не смугут воспользоваться этой возможностью, поскольку преде скорости сваливания у них в притирку уже при 450кг.
http://avions.leger.site.voila.fr/PATAPLUMEI.htm
Masse à vide 190 kg
Envergure 10 m
Longueur 6.00 m
Surface alaire 16.50 m²
Largeur cabine 0.70 m
Train classique, roues Ø 400
Réservoir avant 40 l
Moteur VW 1600cc
Puissance maxi 50 cv
Masse maxi 370 kg
Nombre de places 1+1
Vitesse maxi 140 km/h
Vitesse croisière (60%) 120 km/h
Vitesse de décrochage 60 km/h
VNE 140 km/h
Finesse 9 à 80 km/h
Taux de chute mini 2.5 m/s
Taux de montée 3 m/s
Taux de roulis (45° à  45°) 4 s
Distance de roulage au décollage 100 m
Distance de décollage (15 m) 250 m
Distance de roulage à l'atterrissage 100 m
PATAPLUME II
Masse à vide 278 kg
Envergure 9.11 m
Longueur 6.43 m
Surface alaire 15 m²
Largeur cabine 1.10 m
Moteur VW 2000cc
Puissance maxi 80 cv
Masse maxi 450 kg
Nombre de places 2
Vitesse maxi 175 km/h
Vitesse croisière (60%) 150 km/h
Vitesse de décrochage 63 km/h
VNE 180 km/h
Finesse 11 à 100 km/h
Taux de montée 4 m/s
Taux de roulis (45° à 45°) 3 s
Distance de roulage à l'atterrissage 150 m
Distance d'atterrissage (15m) 400 m
Consommation (60%) 12 l/h
Вот только эти 450кг max. взлетного фикция для того чтоб влезть в класс ультралайтов! 🙁
Поясню речь про 2х местные с ротаксами от 80-100л.с.
Объясняю, вес пустого у всех примерно в диапозоне ~250-290
два человека принимаются равными по 75 кг кажеться (или 80) в итоге уже набегает 150-160,
а кто переваливает 80кг достаточно много + топливо литров 60 минимум
и того уже переваливает за 450 кг 🙁
Где-то встретил даже такое тех описание у одного ВС
Max. take-off: 450 kg (ultralights)
570 kg (experemental)
[quote author=Shturman Zeleniy [Green] link=1151818764/45#48 date=1151911427]Вот только эти 450кг max. взлетного фикция для того чтоб влезть в класс ультралайтов! 🙁
570 kg (experemental)[/quote]
у многих UL MTOW более 472кг: CTSW-600kg, CH601-590kg, т.е. в Европах он ультралайт, в Америке LSA
CAP 482
British Civil Airworthiness Requirements
Section S - Small Light Aeroplanes:
Maximum total weight authorised (MTWA) not exceeding 300 kg for
single seat aeroplanes, or 450 kg for two seat aeroplanes.
Maximum weight not less than the weight which results from the empty weight of the aeroplane, plus a weight of occupant(s) of [86] kg for a single-seat aeroplane, or [172] kg for a two-seat aeroplane, plus the required minimum equipment, plus fuel for at least 60 minutes flight at maximum continuous power.
Спасибо Kestas!
[highlight]#0035[/highlight]
[highlight]CAP 482[/highlight]
[highlight]British Civil Airworthiness Requirements[/highlight]
Maximum total weight authorised (MTWA) not exceeding [highlight]300 kg[/highlight] for
single seat aeroplanes, or [highlight]450 kg [/highlight]for two seat aeroplanes.
www.
Foto:
Price:
...от Дениса!
[highlight]№0036[/highlight]
[highlight]PATAPLUME II [/highlight]
Masse à vide [highlight]278 kg[/highlight]
Envergure 9.11 m
Longueur 6.43 m
Surface alaire 15 m&#178
Moteur VW 2000cc
Masse maxi [highlight]450 kg [/highlight]
Nombre de places 2
VNE 180 km/h
www.avions.leger.site.voila.fr
...from Denis!
[highlight]№0037[/highlight]
[highlight]PATAPLUME I[/highlight]
Masse à vide [highlight]190 kg [/highlight]
Envergure 10 m
Longueur 6.00 m
Moteur VW 1600cc
Masse maxi [highlight]370 kg [/highlight]
VNE 140 km/h
Finesse 9 à 80 km/h
www.avions.leger.site.voila.fr/PATAPLUMEI.htm
