This is the only prototype made. It is a DARPA Military project made by SWB. It is a turbo shaft that weighs in under 40lbs and produces 101HP. Yes that is right! 40lbs self contained free turbine turbo shaft at 100HP. Test data shows 460 Lbs of static trust off a 3 bladed warpdrive prop. Perfect for a VTOL device helicopter or ultralight. This is not a RC type engine with limited life. It has its own self contained oil system that lubricates all systems including the gearbox and the engine. The main engine has its own oil system, and it does not require mixing oil with the fuel. This engine does not require deloading the engine during start up since it is a free turbine and has N1 and N2. You also do not need a special prop to run this engine. A warp drive or Ivo will do just fine. All rights, molds, tooling and programming where sold from SWB to a ultralight company in Florida 70,000USD then to me. Engine comes with test stand as well, but engine will be taken off prior to shipping. This project cost the Military 1.2 Million dollars. I have thousands of pages of documents on every aspect of the project that I will include. I have all the drawings, some of the CNC code and pictures of every step of the project. I also have several videos of the engine running. This engine comes with everything pictured except the alternator and the prop no molds or tooling are included. I have not ran the engine with the controller provided, but tested it with a voltage controller on a fuel pump instead. Contact 661 428-1850 with shipping questions . It is the buyers responsibility on arranging shipping. . US sales only
Турбопроп в форме буквы "Гэ"?Ну-ну...
ТС турбину на Ротакс хочет,Веггер какой-нибудь бизЪнесЪ провернуть как всегда...Я не очень понял, речь про наддув или про то, что исходный двиг используется как газогенератор для ТВД?
Веггер хочет чтобы было больше товаров хороших и разных. А хорошего способа другого акромя как через тот самый бизнес пока что никто не напридумывал....,Веггер какой-нибудь бизЪнесЪ провернуть как всегда...
Конечно можно! А вот как правильно установить, вряд ли Вам тут кто даст пошаговую инструкцию. Отдельные советы и предположения не чем Вам не помогут, или введут в заблуждение. Коллега из США это прекрасно демонстрирует.Можно ли устанавливать турбину на 912s 100лс.Хотелось бы узнать все +и-.
Да конечно же читаю . Но... каков вопрос таков и ответ А Вы как с этой сложностью боретесь ?@ А.Веггер, Вы хоть читаете вопрос ТС-а? При чём тут турбопропы?!
