Пришел ответ от Stein Air. Могут приступить к изготовлению панели только через два месяце и делать будут еще три месяца. Видно у парней полная загрузка.
Конечно, предложили полный комплект лучших приборов.
Стоимость $41000 плюс доставка, дороговато будет.
Наверное, возьмем за основу Dynon D100 -$2355
Для двигателя DynonEMS-D120 -$1970
Плюс дублирующие УС-450, ВАР-10, и ВД
Ответчик, радиост. Icom -210
И наверно пока хватит.
Кто еще что посоветует?
Dear Yuriy,
Here is the information you requested. The prices I have quoted you do
not include wiring stick grips or trim systems. If you need these done I
can add them to the quote. All wiring will be brought out to CPC
connectors and you will be given the mating connector to wire the rest
of the remote systems. At this time we could start this project at the
beginning of August. Once we start the project it will take about 3
months to complete both panels. If you have any questions on this quote
please let me know.
GMA340 Audio Panel $1,275.00
GNS530W WAAS GPS/Nav/Com $11,295.00
KX155/KI208 Nav/Com with Indicator $4,495.00
GTX-327 Transponder $1,675.00
PCD-7100 $1,045.00
KCS55A HIS System (Used) $4,195.00
VM1000C 4 Cyl $2,665.00
RCA22-7 Attitude Gyro w/8 Degree Tilt $680.00
TC02E-3A-2 Turn Coordinator w/8 Degree Tilt $405.00
ASIT210N-3 Airspeed in Knots w/Range Marks $275.00
ALT20MBF-3 Altimeter in Millibars $270.00
VSI2FM-3 2K VSI $110.00
PG2C-12 S.I.R.S. Compass $195.00
GM510-2 G-Meter $270.00
85094 Hobbs Meter $35.00
AK451 406 MHz ELT $825.00
A-510-2 Ignition Switch $105.00
S-1994-1-1 Split Master Switch $20.00
PCA-LRS Lighted Rocker Switches (8) $320.00
7277-2-XX Circuit Breakers (25) $475.00
ETA-60 Alternator Circuit Breaker $85.00
LC-40E Dimmer Assembly $105.00
LW3014 Light Wedges (5) $225.00
RP-3 LED Trim Indicator (3) $285.00
MTA-206N Toggle Switches (4) $45.00
Relays (3) $75.00
Misc Parts (Static Fittings BC Connectors, CPC Connectors) $350.00
Powder Coating & Standard Engraving $800.00
Labor 115 Hrs @ $75/Hr $8,625.00
Panel Total $41,225.00
