Постройка автожира из "Мурзилки"
slavka33bis сказал(а):
те может расходовать 8 л/ч.?
-[ch1079][ch1072][ch1074][ch1090][ch1088][ch1072] [ch1074][ch1089][ch1090][ch1088][ch1077][ch1095][ch1072][ch1077][ch1084][ch1089][ch1103] [ch1089] [ch1041][ch1086][ch1075][ch1076][ch1072][ch1085][ch1086][ch1084]=[ch1087][ch1077][ch1088][ch1077][ch1076][ch1072][ch1084] [ch1077][ch1075][ch1086]
\[ch1073][ch1086][ch1083][ch1100][ch1096][ch1086][ch1081]\ [ch1086][ch1087][ch1099][ch1090].
-[ch1103] [ch1089][ch1072][ch1084] [ch1085][ch1077] [ch1083][ch1102][ch1073][ch1080][ch1090][ch1077][ch1083][ch1100] [ch1044][ch1042][ch1057],[ch1087][ch1088][ch1077][ch1076][ch1087][ch1086][ch1095][ch1080][ch1090][ch1072][ch1102] [ch1101][ch1083][ch1077][ch1082][ch1090][ch1088][ch1080][ch1095][ch1082][ch1080]...
-[ch1076][ch1088][ch1091][ch1075][ch1086][ch1081] [ch1090][ch1086][ch1074][ch1072][ch1088][ch1080][ch1097] [ch1085][ch1072] [ch1057][ch1058][ch1054][ch1051][ch1068] -701 [ch1074] [ch1076][ch1074][ch1072] [ch1095][ch1077][ch1083][ch1086][ch1074][ch1077][ch1082][ch1072] [ch1089][ch1078][ch1080][ch1075][ch1072][ch1077][ch1090] 14[ch1083]/[ch1095],[ch1074] [ch1086][ch1076][ch1080][ch1085][ch1086][ch1095][ch1082][ch1091]=12.
\[ch1088][ch1086][ch1090][ch1072][ch1082][ch1089] 912,80[ch1083][ch1089]\.
-[ch1076][ch1091][ch1084][ch1072][ch1102],[ch1095][ch1090][ch1086] [ch1092][ch1080][ch1088][ch1084][ch1072] [ch1056][ch1054][ch1058][ch1040][ch1050][ch1057] [ch1085][ch1077] [ch1074] [ch1089][ch1086][ch1089][ch1090][ch1086][ch1103][ch1085][ch1080][ch1080] [ch1091][ch1076][ch1077][ch1083][ch1103][ch1090][ch1100] [ch1089][ch1090][ch1086][ch1083][ch1100][ch1082][ch1086] [ch1074][ch1085][ch1080][ch1084][ch1072][ch1085][ch1080][ch1103] [ch1082] [ch1101][ch1082][ch1086][ch1085][ch1086][ch1084][ch1080][ch1095][ch1085][ch1086][ch1089][ch1090][ch1080] [ch1089][ch1074][ch1086][ch1080][ch1093] [ch1084][ch1086][ch1090][ch1086][ch1088][ch1086][ch1074] [ch1082][ch1072][ch1082] [ch1073][ch1086][ch1083][ch1100][ch1096][ch1080][ch1077] [ch1072][ch1074][ch1090][ch1086][ch1084][ch1086][ch1073][ch1080][ch1083][ch1100][ch1085][ch1099][ch1077] [ch1092][ch1080][ch1088][ch1084][ch1099]...
Для Serg 1974
Серёга, я подготовился.
По Ротаксам "912 UL DCDI" и "914 UL DCDI"  информация уже есть.
Эти двиглы практически одинаковы.
Разница, в основном, только в наличии турбины (не вдаваясь в другие мелочи и немелочи).
И у турбированного удельный расход на взлётном режиме составляет 0,287 л. на л,с./час.
У не турбированного - 0,284 л. на л.с./час .
Разница, конечно, не значительная, но это "дело прынципа".
По менее нагруженным (одинаковым для обоих ДВС) режимам чёткой информации нет.
Данные я взял с сайта "АВИАГАММЫ".
P.S. Ладно Серёга, будем считать, что я (по поводу значительно большего расхода у турбированного) действительно ОШИБСЯ.  :-[
http://www.reaa.ru/yabbfiles/Attachments/sized_sized_IMG_0662.JPG
=OK-KUR-11=
/lietajustshyj shifanier!
Я почемуто так и заподозрил.
:-[  Но ведь, это-ж самолёт.
🙂  А между нами и ими огромная разница.
🙂  Даже учитывая, что они - есть "летающий шефаньер."
Вы так не считаете?
Вы так не считаете?
-если идти дальше,так дойдём до мотопланеров
\качество порядка 40\ или мотодельтапланов с жёстким крылом\кач.25\.
-если принять что аэр.качество а-жира =5\там лопасти были слишком большими=8,4м\
то при весе 300кг нужна тяга ок.60кг,что соотв.порядка 20лс.
-практические данные=завтра.
henryk, не могли бы Вы ещё разок выставить фото того автожира, о котором мы ведём речь?
Пусть даже фотография будет самая маленькая.
Или укажите номер сообщения, в котором это фото уже есть.
Для AcroBatMan
Александр, не подскажите(?), в калькуляторе Тервамяки (возможно, с фамилией ошибся. Не судите ...) для расчётов
тяги забит трёхлопастный маршевый ВВ или двухлопастный?
Или это не имеет значения?
Кстати.
А Вы-то как считаете(?), возможен ли расход 8 л/час
- на двухместном автожире-тандеме,
- летящем с одним только пилотом на борту
- на самой экономичной скорости неприрывнопродолжительное время (допустим, в течении одного часа)
- в строго горизонтальном полёте?
Понятно.
Значит и Вы считаете такой расход нереально скромным.
Вот этот да?
    14,6 КБ · Просмотры: 108
-да,ентот.
-Богдан и его помощник утверждают:во время
двухчасового облёта\фрагменты на видео\
мотор сьел 20л=\столько доливали до полна после полётов\.те.10л/ч при разных нагрузках мотора...
-он же тестировал такой мотор в машине=500км в течении 4 час=32л/8л/ч\.
-он же на такой же тележке с крылом\дельта\
СТРАТУС\на заднем плане\ при учебных полётах=взлёты и посадки без пассажира=6,2л/ч!
-поэтому поддерживаю вчерашние заявления...
ЗЫ:в этой тележке\без обтекателя\ нет задувания в голову,а в ноги поступает тёплый воздух от мотора,самотёком.
slavka33.150 , Вам сообщили экспериментальный результат, который наблюдали и другие пилоты: год назад я замерял вместе с Вадимом Александровым, Лазаревым и т.д. Аналогичный результат был и у Юры Корнея, но он старается воздерживаться из-за критики. henryk отлично знает теорию, но все равно для него истина дороже!
Сейчас задумайтесь о теории, может что-то надо подправить? Факт, что при некоторых условиях полета расход топлива бывает ниже ожидаемого!
Может Serg 1974 прав, сказав:
Главная причина расхода топлива у автожира это качество ротора и наличие кабины и ее аэродиномического качества
Если не можем объяснить, надо ждать, а не критиковать.
[quoteи подкрутки,если
Рышард найдёт для этого время... [/quote]
-конечно,нужно будет решить проблемму момента реакции ротора...
RUSO сказал(а):
Если не можем объяснить, надо ждать, [highlight]а не критиковать[/highlight].
Всеволод, "да Боже упаси" меня от критики.
Высказывание сомнения - это не есть "критика".
Мне любопытно, почему отмалчиваются "ОСНОВНЫЕ".
Могли бы поставить, ну как минимум, точку с запятой.  :-[
