Shturman Zeleniy [Green]
Все, что не делается - к лучшему!
- Откуда
- Москва
Прошу прощения немного неправильно перевел первоначально, но там вроде говорится, что можно автомобильный если затруднения с 100LL
и еще, только электрический ВИШ или есть и гидравличиский под Subaru ?
#3 ECONOMY
A complete Eggenfellner package actually costs a little less than a traditional aircraft engine. So you save from the start. Plus, you don’t have to go out and get all the connectors, hoses, clamps and other this’s and that’s that can easily add up to the cost of a dream vacation. So you save more there.
When you have your engine installed and you’re flying, you’ll run more efficiently and burn less fuel. By reducing the fuel flow, you will carry less fuel thereby reducing the weight and increasing your cruising range. Your flight will go faster as you don't need to make as many intermediate stops. So you save again.
100LL can be used to operate your engine. This fuel might be fazed out in favor of the more environmental friendly UL82 which you can use in your engine along with automobile fuel. So when 100LL becomes unavailable, you will still be flying high while others stay dry.
All in all, an Eggenfellner aircraft engine can save you a bundle, and leave you more money to spend while enjoying your newly finished plane.
#3 ECONOMY
