NIKOLAI
Строить и летать!
- Сибирь матушка
Здесь:http://www.greatplainsas.com/sclgblock.htmlЗа совет VW-2180 спасибо, сколько в нем веса.?
2180cc VW Long Block Engine Kit
82mm Stroker Crankshaft X 92mm
Rated at 70 HP continuous and 76 HP at takeoff
Long Block kit weighs 121 lbs. without accessories
This kit includes the Force One Prop Hub
and Main Bearing,
plus all necessary maching work for
the Force One Prop Hub.
FRONT DRIVE SPECS TYPE 1 TYPE 1 TYPE 1 TYPE 1 TYPE 1 TYPE 1
ENGINE DISPLACEMENTS 1600 1700 1835 1915 2180 2276
Take off HP, 3600 RPM (MAX) 55 60 65 69 76 80
Continuous HP, 3400 RPM 50 55 60 65 70 76
Bore (mm) 85.5 85.5 92 94 92 94
Stroke (mm) 69 69 69 69 82 82
Displacement, in CC 1584 1700 1834 1915 2180 2276
Compression Ratio 8.0: 1 8.0: 1 8.0: 1 8.0: 1 8.0: 1 8.0: 1
Minimum Fuel Octane 96 96 96 96 96 96
Firing Order 1234 1234 1234 1234 1234 1234
Magneto Slick Slick Slick Slick Slick Slick
Harness Slick Slick Slick Slick Slick Slick
Plugs (with Spark Plug Adapters) 7902 7902 7902 7902 7902 7902
Propeller Drive 1.1 1.1 1.1 1.1 1.1 1.1
Carburetor, Float Bowl 1617 1617 1821 1821 1821 1821
Electric Fuel Pump Opt. Opt. Opt. Opt. Opt. Opt.
Starter Geared Geared Geared Geared Geared Geared
Alternator Amp Output 22 22 22 22 22 22
Prop Flange Diameter 5" 5" 5" 5" 5" 5"
Bolt Holes in Flange 6" 6" 6" 6" 6" 6"
Prop Flange Bolt Pattern, o/c 4" 4" 4" 4" 4" 4"
Prop Pilot Diameter 2" 2" 2" 2" 2" 2"
Prop Pilot Depth .375" .375" .375" .375" .375" .375"
Prop Bolt Diameter .312" .312" .312" .312" .312" .312"
Weight in Pounds 159.2 160 163 163.2 164.5 165
74,6кг
