Мне нравится этот гидросамолет!
Календарик на Март для настроения.
    50,2 КБ · Просмотры: 213
Кот-Баюн
Подскажите пожалуйста, где можно найти чертежи на Spencer S-12 ? В интернетах что-то глухо все по теме этого самолета. Заранее спасибо!
Плохо ищете:
http://www.republicseabee.com/
http://www.seabee.info/
1. Robert Kerans
robertkerans@earthlink.net
Kansas, Illinois, United States
SOME ACCUSED OF BUILDING THEIR OWN HOME-MADE "SEABEE" AMPHIBIAN!
    Patterned after the Seabee, by the designer of the Seabee, this "Spencer Air Car" is a big, comfortable, four-place amphibian of proven design. (38 are licensed and flying).
Complete set of blueprints available for $300.00.
Please contact
Mr. Robert Kerans of Spencer Aircraft
Box 327
Kansas, IL  61933
For Details of Aircar or Seminar Tel (217) 948-550
Mrs. W. Kerans
217-948-5505 or 847-882-5678
Fax: 847-882-0123
$300 + $25 shipping
2. Gary Lamb
glamb@borough.kenai.ak.us
Sterling, Alaska, United States
3. Douglas Palmer (этот самолет на календаре eaa.org, ниже ссылки с фото постройки)
HHshitmail@mindspring.com
San Francisco, California, United States
N351DP
Homepage at http://dougnlina.home.mindspring.com/Home.html
http://www.abpic.co.uk/
Percival H. Spencer had designed the Republic Seabee light amphibian aircraft in 1946. After leaving Republic, he designed the on-off two-seat Air Car. In the early 1970s he designed the improved and larger four-seat S-12-D Aircar, which retained the basic layout of the Seabee.
The Air Car is built from wood, steel and glass-fibre. It has a strut-braced high wing and the cabin and fuel-carrying floats are similar to the Seabee, but the tail unit is more angular and a retractable tricycle undercarriage is fitted.
In addition to examples constructed by Spencer, plans of the design have been sold for home construction and the first amateur-built Air Car flew in September 1974. Over 50 had flown by 2001. Examples are currently (2009) flying in the USA and Canada.
Variants
S-12-C Air Car 1941, 2-seat; 110 h.p. Franklin; span: 33'7" length: 23'3", load: 527. Wood-veneer construction on a metal frame.
S-12-D Air Car 197?, 4-seat; 260 h.p. Lycoming O-540-E4B5; span: 37'4" length: 26'0", load: 1050, range: 600.
S-12-E Air Car 197? = 4-seat; 285 h.p. Teledyne Continental Tiara 6-285-B; range: 800.
S-14 Air Car Junior
two-seater, twin booms, Lycoming O-320, one example
Specifications S-12-D (variant)
General characteristics
Crew: 1
Capacity: 3 passengers
Payload: 1,050 lbs (476 kg)
Length: 26 ft 0 in (7.92 m)
Wingspan: 37 ft 4 in (11.38 m)
Height: 9 ft 6 in (2.9 m)
Empty weight: 2,050 lbs (930 kg)
Useful load: 1,050 lbs (476 kg)
Max takeoff weight: 3,100 lbs (1,406 kg)
Powerplant: 1[ch215] Lycoming O-540-E4B5, 260 h.p. (191 kW)
Performance
Maximum speed: 147 mph (237 km/h)
Cruise speed: 135 mph (217 km/h)
Range: 700 miles (1,127 km)
Rate of climb: 800 ft/min (244 m/min)
    63,3 КБ · Просмотры: 256
Бааальшая птичка...
ЛТХ:
Модификация   H-4
Размах крыла, м   97.54
Длина самолета,м   66.45
Высота самолета,м   24.08
Площадь крыла, м2   1061.88
  пустого самолета
  максимальная взлетная   136078
Топливо, л   52996
Тип двигателя   8 ПД Pratt Whitney R4360-4A
Мощность, л.с.   8 х 3000
Максимальная скорость, км/ч   351
Крейсерская скорость, км/ч   282
Практическая дальность, км   5633
Практический потолок, м   7165
Экипаж, чел   5
Полезная нагрузка:   максимально до 59000 кг коммерческого груза
    13 КБ · Просмотры: 184
    46,6 КБ · Просмотры: 173
    41,7 КБ · Просмотры: 175
Подскажите пожалуйста, где можно найти чертежи на Aventura II
Однако симпатяг собрал.......уважаю.... [smiley=thumbsup.gif] [smiley=cheesy.gif]
    22,8 КБ · Просмотры: 273
Seawind в Остафьево:
красава.........
Очень интересно послушать подробности о необычном Чирок и увидеть его фото другого ракурса.!
Спасибо всем водолетающим.!
присоеденяюсь хотелось  бы тоже увидеть и услышать о столь необычном  иноплонетянине...... 😀 😀 😀 😎
красава.........
присоеденяюсь хотелось  бы тоже увидеть и услышать о столь необычном  иноплонетянине...... 😀 😀 😀 😎[quote
author=765F4C3A0 link=1198071166/51#51 date=1198414066]
Cпасибо всем за отличные фото,а Pkk персональное.! Кто может рассказать о лет. качествах Ч-27.?
ЛТХ Че-27 можно посмотреть по этой ссылке:
http://www.sama.ru/~chernovb/che27.shtml
Это данные самого Чернова... Мне просто запомнилось высказывание одного пилота, имевшего дело с самолетиками Чернова, на форуме Авиамастера - Че - это "честный самолетик"... 🙂, то есть Чернов свои ЛТХ не преувеличивает, и неизбежные "пенки" доводит до ума...
[/quote]
Это правда я в своё время ему помогал....... 🙂
Где-то под Москвой - 10 и по колено в снегу.Красивый полет!
    22,4 КБ · Просмотры: 220
    35,8 КБ · Просмотры: 243
    32,2 КБ · Просмотры: 240
