А там полный аут нашим совковым (других мы не наработали) канонам.
" More on Seanergy roadable airplane synergies:
1) The new engine is the same engine that would power your house at 20 kw to the grid. Get some use out of the wing when not in use.
2) You buy the pod with the engine in it and then buy the wing with its engine (two complete engines) and they can share parts.
3) They work together or separate and allow multiple redundancy of the engine.
4) Each engine has 5 parts with one extra part that can work on either engine.
5) Each part creates internal volume production in one engine
6) Each part can be used in many industries, such as a trackhoe, Real estate, commercial, boating, etc..
7) If one part fails, other parts can back up.
8) Each part can work together and eliminate the need for gears to change torque levels
9) Can work with or without a drive shaft easily without special torsional resonance devices
10) It is like having a 4-8 engine airplane.
11) The wings serve as intercoolers and icing is not an issue, and when stopped the engine acts like a thermal battery for heat or cold
12) Mobile electrical power with added 20 kw motor if desired, making hurricane and flood rescue easy.
13) Can function as a flying Hummer of sorts and allow all people to have air power with added equipment from the military
14) Can patrol at car highway speeds and get great fuel economy for boarder patrol, highway patrol, police and fire, yet go fast
15) Can scoop up water and act as a water bomber for forest service use. Each firefighter has his own airplane
16) on and on
Competition? Hmmm I'm up to 51 synergies with this design. The other guy maybe 3-6 if lucky.
Holden
It can descend quickly to get down fast and has 2.5 ft landing gear stroke for 1500 fpm impact landing just like a carrier landing. Should be a blast. "
из=
http://www.homebuiltairplanes.com/forums/aircraft-design-aerodynamics-new-technology/14146-holdens-roadable-design.html
-Геннадий Михайлович=наверно нам надо на пенсию,если сравнивать наши проекты с выдумкой бешенного американца
\работал инженером у ПОРШа-специалист по аирбегам\...
-я там не всё понял,но есть и нормальные мысли=сделать
нижнюю часть фюзеляжа также прозрачной,передние и задние
колесо однорядные+два боковых вспомогательных и целый
воз других нестандартных решений.
к сожалению,нет рисунков!
http://www.youtube.com/watch?v=HhdsXX0uidA
=krylja dielta,tipa kak na video...
